  #1
Old July 6th, 2004, 12:55 PM
otim49 otim49 is offline
Default 98 evinrude 35 hp 2 stroke model #e35qleca
When my gas tank gets low it starts to sputter and lose power, I then change tanks and add fresh gas and it will start but when I acelerate it has a burst of power then stops, I continue stopping and starting until I get back home. I check the oil that is usually fine but add a bit clean the spart plugs and I have the same problem. I checked the hoses for leaks and nothing is apparant. The following day I try to start it and it runs good, this has happened several times so far. Any suggestions?
  #2
Old July 6th, 2004, 01:37 PM
JB's Avatar
JB JB is offline
Default Re: 98 evinrude 35 hp 2 stroke model #e35qleca
Your engine is a 1998, Otim.You may have water in your fuel, Or you may have a failing fuel pump, air leak in the hose, or debris in the carb float bowl.Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old July 6th, 2004, 03:13 PM
JB, thanks for the advise I have the same probelem with both tanks, but I can add some dry gas to the tanks and see what happens. The line looks good but I have two differnt fittings on the tanks (could that cause some air leakage)? As far as the fuel pump is that a big job and can you recommend a good repair manual to buy? Thanks
  #4
Old July 6th, 2004, 04:12 PM
JB's Avatar
JB JB is offline
Most wrenches prefer the OEM manual, Otim.www.kencook.comBut I find the aftermarket manuals easier for novices to follow, and they don't require special tools, fixtures or equipment. http://www.iboats.com/ubb/ Good luck.
__________________
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
99 MODEL 4 STROKE MERCURY 40 eskimo man Mercury & Mariner Outboards 3 April 7th, 2009 02:00 PM
Mariner 50 4 stroke model OG620526 D4no Mercury & Mariner Outboards 3 June 14th, 2006 09:07 AM
nissan 5 hp 2 stroke model ns5b dean ray Honda & Tohatsu/Nissan Outboards 3 July 3rd, 2004 11:04 PM
7.5hp Honda 4-stroke, Model # B75 MansellMan Honda & Tohatsu/Nissan Outboards 4 March 16th, 2002 11:07 AM
Old Honda 7.5hp 4-stroke, Model# B75 MansellMan Honda & Tohatsu/Nissan Outboards 0 March 12th, 2002 08:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
