steviecops
- Oct 3, 2003
- 585
I fitted a new tachometer to day and got erratic readings. It is a Smiths Tach, (a good make, made in the U.K), made for outboards. I wired it to the plug in the control box.<br /><br />It seemed to work O.K at low revs, up to 2-3k, but when I increased the revs, the tach needle dropped first then gradually climbed again. But it never seemed as if it was reading high enough.<br /><br />Could this be a rectifier problem, or maybe a loose or dirty wiring connection in the control box? <br /><br />I did take the control box apart and found the ground connection screw was loose and the terminals on the wires were dirty. I've cleaned and tightened the connection, but haven't tried the tach since then.<br /><br />Is the dropping needle consistent with any common faults? I'd appreciate any help on this.<br /><br />Many thanks<br />Steve
