My voltmeter gradually climbs to 18 volts while running yet the actual voltage as measured by a high quality voltmeter is 15.2 volts. Is this strictly a meter problem or is the 15.2 volts too high? Is there a voltage regulator on this motor? Shouldn't the actual voltage be more like 14 volts? Could this be a battery problem? Thanks for in advance for the help!
