1994 Johnson 70 HP starter runs key off
saltydawwg
I let the battery run low, went out for the first time this season and the motor wouldnt start. She cranked a few times before the battery went completely dead. I disconnected the dead battery and replaced it with one of the trolling motor batteries (these were also very low). When re-connecting the cables, the positive cable sparked and the starter runs. The key is in the off position. I have since replaced the battery, but when I tried again to re connect the cables, the starter fires with the key in the off position. I pulled the kill switch, and the starter still fires. I would appreciate any ideas you might have. Thanks.
ob
Re: 1994 Johnson 70 HP starter runs key off
I'd look into the ignition switch first.Could also be a bad starter solenoid.The engine kill lanyard just kills the spark.
saltydawwg
OB,<br />Thanks for the help. It turned out to be the starter solenoid. As I understand it, low voltage to the starter solenoid, in this case my dead battery, will cause the solenoid to go out. Got a new battery, replaced the starter solenoid, got the motor started and am ready for the fishing season. Thanks again!
ob
Thanks for the kind words and for posting back.Hope you have a trouble free boating season.
