I did my best to look thru most of the pages of info. on the board, but couldn't find what I was needing. <br /><br />I have an older Johnson 5.5hp Seahorse. I looked on clamp bracket and no Ser.# or Model #. I've looked all over the thing for numbers, but only stamped manufacturing numbers on various parts. There appear to be 2 holes on port side of clamp bracket that could have held the id plate, but no plate, just 2 small holes about 2 inches apart. I think it is about 1954, based on pictures on internet pamphlets, but can't be sure. Pressure tank. Thats about all i find. Is there a way to tell?? 2 cylinder, 2 cycle, green in color. carb has glass collector bowl on bottom, face has hi/lo speed adjustments for carb. (suppose several years around then did). In any case, need help discovering year/etc.. for parts needs. Thanks!!
