Hi to all,<br /><br />Power asst. piston never did work on my 48 Johnson, very hard to raise (standing behind motor grabing prop area and raising). But it would stay up when you flipped the lever to hold position. <br /><br />Now it will not stay up it goes back down no matter what position the lever is in. Did I blow the seal? or is it out of adjustment? I did remember the last couple of times when I flipped the lever to lower it from the tilt position would not move right away?<br /><br />And to get to the seal I would think the top rod would have to be removed from the pivoting part of the motor right? Well a few years ago I wanted to switch the power asst. to PT&T but I couldn't get the top rod out that the top of the piston connected to. Is there a secret or just a pain in the neck? Also I didn't what to break the cast trying to beat on the rod. I also attempted to drill but its stainless and was very hard to drill.<br /><br />Any suggestions on removal of the power asst. piston, or should I just invest in a aftermarket PT&T? I saw one on this site for about $450 and am thinking about it. May be easier than fooling around with this piston? <br /><br />Has any one had any dealing with the CMC PT-130? How durable? Can you order parts? <br /><br />Thanks for any input.<br />Beck<br />
