The intake inspection port covers with the hose fittings go on the bottom cylinders (#3 & #4).
Note that the cylinders are numbered as follows: Starboard (right bank) top=1, bottom=3. Port (left bank) top=2, bottom=4.... not the way you listed them. Back up from the engine and look at the s/plugs and you'll see that they line up as I've listed them here.
Sometimes the casting numbers on the parts are identical to their part numbers. If so, the cover for #4 (port) cyl would be 323045, and the cover for the #3 (starboard) cyl would be 310532.
