Re: Test stator off motor?
You will have two leads coming from the stator, yellow, yellow-gray. Place an ohm meter on the low ohms scale between these two leads, you should have only about one ohm's resistance. To check for a short to ground, place the black lead of meter to Stator core, red lead to yel, then to yel.-gry. With meter on high ohm's scale you should have a very high reading.
