Thermo switch
ddaigle
1971 60 horse johnson, Have 2 wires going to bottom of cylinder head. Manual says they go to thermo switch, but nothing else. What the heck is a thermo switch and can I disconnect it without harm?
Dhadley
Re: Thermo switch
It was intended to partially close the choke when the motor was only warm. <br /><br />Good theory, huh? <br /><br />They later sent out a bulletin saying to disconnect that thing.
ddaigle
Re: Thermo switch
Thanks DHadley, finally have this motor running good after mucho problemas and stupidity on my part. But you guys have straightened me out and helped me an amazing amount. Can't thank all of you enough. :D :D :D
Dhadley
Re: Thermo switch
The smiles are thanks enough.<br /><br />We're glad its working well!
peiboy
Re: Thermo switch
Dhadley, do these wires run from the junction box around to the other side and into the engine block. Where they go into the block there is some sort of rubber gasket around. Wires like that corroded off my 72 50 hp johnson and i was wondering what they were. Engine seems to start and run fine with the muffs .
