Help I can't start my 1983 35 hp Johnson
Naa_Danno
Was crab fishing the other day, (doing well by the way) and I shut my motor down to drift for a while. When I started my engine up, and put it in forward, I went backwards, then when I put it in reverse I went foward. I shut down the engine, then I tried to restart it, it started but with some effort, when it started it would idle at high revs. I then shut it down again and could not get it started. When trying to start the engine it back fires almost ripping my arms out of my sockets.. :confused:
D
DJ
Guest
Re: Help I can't start my 1983 35 hp Johnson
Couple things to look for.<br /><br />Did the flywheel key shear?<br /><br />Is this thing really carboned up?
Naa_Danno
thanks for your reply DJ<br /><br />Yes it did, and I have replaced it, (about an hour ago) now it runs great, expect for there is no water coming out the tell tale, I looked at the impeller and it's fried, I am going to have to buy the kit. Question, when the engine was running backwards would it of flipped the fins of the impeller over causing it to over heat?
D
DJ
Guest
Naa_Danno, <br /><br />Yes, turning an impeller backwards is bad medicine. Can you account for all the pieces?<br /><br />Glad you found it. Good work!<br /><br />You may want to decarb this thing too. That may have caused the kickback to begin with.
Naa_Danno
wow you are online!!! cool responed before I could edit my post :) <br /><br />Yes I could count for all the pieces but the rubber was melted in the housing.
Naa_Danno
Hi DJ<br /><br />Not sure what you mean by decarb?
