Re: Tilt Assist
Hi ya' snipe...welcome to iboats.<br /><br />Yea...the tilt assist can be a pain. Not sure which nut ya' took off so could ya' explain that a little better?<br /><br />If you can still get to it, the cable attaches to the top of the cylinder. Remove it and see if the cable is still free when unattached. You can operated the cylinder with a screw driver. Put the screwdriver under the plunger in the cylinder and pry up. Make sure the engine is locked in the up position or it will come down. If it's really hard to move or sticks, try a little lube around it. The cylinders are a non repairable item and are pricey to replace. The cables are replacable.<br /><br />Keep us posted.
