Re: cold natured evinrude
Try this;<br /><br />1- Pump the bulb to pressure the fuel delivery system.<br />2- Turn the key to "On". Do NOT engage the starter.<br />3- Push the key in to activate the primer and count to eight.<br />4- Turn the key to "Start" (engage the starter).<br /><br />You may have to "tap" th primer a couple of times. You should not have to advance the throttle as your motor has the "Quick start" feature.<br /><br />Make sure your carbs are clean, you're using fresh 87 octane and Champion spark plugs.<br /><br />If your carbs havent been cleaned in a while, do it.
