phatmanmike
- Oct 24, 2003
- 3,869
hi. i have rebuilt the carb twice now, replaced head gasket, base gasket, coils, plugs, wires, points, condensors. it has hot blue spark from both plugs. ive seen it...still wont start...the reeds were gummy and sticky, i removed them, took apart and cleened in my "gunk" carb parts cleaning solution.. replaced back on, still wont start.. compression is 90lbs in both cylinders...but no start...<br /><br />if i put fuel directly into cylinders via plug hole, it runs for 1 second...<br /><br />if i squirt fuel directly into carb and close choke, nothing...<br /><br />i am gonna order "boysen power reeds" right after this....<br /><br />heres my questions.. could it be the ignition timing.. how can i check it without the engine running...<br /><br />what could i have missed..... im at my witts end here<br /><br />mikey
