Hi there, I have a 74 evinrude model number 6402c c 73119. 6 hp. Last year I was having trouble and changed the fuel pump which fixed my woes for the summer. This year when I started it up after storage for the winter (with gas stabilizer)it would start after quite a few pulls but run rough at the top end. The plugs were black and very little spark so at the suggestion of a local shop I checked the coils and sure enough one was cracked. I have replaced the coils, points, condensers and plugs.After that it idled like a top and after just starting i can rev it up no problem. Once it warms up though it will still idle fine but there is no top end power and it smokes and runs rough. I have also cleaned the carb and installed a new carb kit.
One thing that I did notice is that pulling the plugs out the top one is black and the bottom one is remaining white. Could I have blown the head gasket??
