You heard exactly opposite. Do not use anything but Champions in an Evinrude/Johnson 2-stroke. Use the same plug number (or eqivelant Champion) and gap them at .030".
Use OMC/Bomardier "Hi Vis" gear lube. Replace the lower unit fill and drain plug seals when you service it.
