smokeybacon
- Apr 6, 2004
- 1
I recently purchased a 10hp 1957 Johnson Seahorse. Model number QD-17. The previous owner said he had the powerhead rebuilt a couple years back and also installed new coils and points. <br />My question is, do I still need to run an oil fuel mix of 24:1 like the manual suggests, or can I run it on leaner 50:1 ratio since it has been rebuilt with new components. It smokes quite a bit when I run it in the tank at 24:1 and I'm wondering if a 50:1 would remedy this.<br /><br />I also noticed that one of the coils has a small crack in the casing. Should this be replaced right away or am I ok to go out on the lake the way it is?<br /><br />Thanks for any info.
