WORN OUT SKEG
rglines
Bought a great 40 HP Evinrude - runs great but skeg was ground off by previous owner (not on purpose, I suspect he dragged it out of the water with the motor down)!.<br /><br />Can I get a new case, or can someone build up the old skeg? I noticed screw on plates for larger engines and outdrives, does anyone know of same for small OB?
mountainboy
Re: WORN OUT SKEG
Hi, Ro--a skilled welder can fix that skeg right up for you.
JB
Re: WORN OUT SKEG
Howdy, Ro.<br /><br />There is a model of the SkeGGard stainless steel skeg replacer/protector that will fit.<br /><br />Costs about the same as having a built up aluminum skeg and lasts a lot longer.<br /><br />Good luck. :)
