Re: converting long shaft to shorter shaft.
HAVE TOO? While the answer above is the text book answer, they can be successfully cut cut and welded without any ill affect if done professionally on lower HP motors like yours.<br />This would have to be done at a speed shop that does racing and such. For the other tubes you can cut them as well and have the aluminum exhaust tube welded and the water tube I cut out the 5 inches out in the stright section where I made my own inspection plate on the side of the lower leg,and use a compression fitting found at any hardware store. This is low pressure water.I and many others have done this, mine has been running for over 10 years and no problems. I think many posters forget this is backyard maintanence and pocketbooks aren't endless. Yes you should go buy a new shaft I saw a guys post last year say it was 200.00 plus a used one from a outboard grave yard would be around 60-100 bucks and the other parts are about 20 bucks each used.My cost was about 40.00 dollars! I would never recomend doing this on a newer type motor,but yours is 22 years old.<br /> steve
