Re: Wont start
get the thickest your pocket book will allow, i use 4 guage, as thats about all i could fit through the hole in my cowl hood. could also be a short somewhere in the switch, try bypassing the wireharness all together with a simple wire and push button switch connected directly to selenoid, if that doesnt work, connect your poss + jumper cable( yes , the ones that came with your car) to the poss terminal on starter and the neg- to a good known ground, watch out for the sparks, it should spin instantly, if not, your starter is bad and may be able to be rebuilt.
