Re: 1989 225 johnson loses power
If you're speaking of the large black coils, it's hard to say what that waxy substance is other than it may simply be the factory coating on the coils.<br /><br />One other common problem wich causes weak or non existent spark is a intermitent short in the ignition switch. Before removing the flywheel to visually inspect the stator, do the following.<br /><br />Remove the s/plugs. Rig up a spark tester whereas you can set a 7/16" gap. Crank th engine over<br />and observe the spark which should be a strong blue lightning like flame.... a real strong wide snap!<br /><br />I'm assuming that you're not obtaining that type spark by your previous post.<br /><br />Now, disconnect the large RED main electrical plug at the engine. Crank the engine by using a small jumper from the battery terminal of the starter solenoid to the 3/8" nut terminal that engages the solenoid (not the 3/8" ground nut).<br /><br />If you now have the proper spark, either a short exists in the instrument cable leading to the control console, or the ignition switch has a short between the two "M" terminals. The usual cause is the ignition switch, in which case replace the ignition switch.<br /><br />If still no spark, there is a very remote chance that a short exists in the engine wiring harness. You can test that by disconnecting the black/yellow wire(s) that would be connected from the harness to the powerpack, then cranking the engine again.<br /><br />If still no spark, the only component left in the circuit is the stator (and of course the powerpack). Removing the flywheel will allow a good visual inspection. Good luck.
