69 evinrude 6 hp no wont rev up
buddie989
i have a 69 6 hp evinrude i just bought i rebuild the carb new fuel pump and plugs now motor will idel ok but wont rev up when i check the plugs the have dark grit on them gas mix is 50 - 1 plugs are J4C <br /><br />i need help
rickdb1boat
Re: 69 evinrude 6 hp no wont rev up
Check compression... Is that a 1 or 2 cylinder?
Paul Moir
Buddie - first off, Welcome. I've got a few questions:<br />When you pump up the primer bulb, does it get hard? No gas flowing out of the carb's throat?<br />Also, when you set up the new carb float, did you make sure it was flush with the carb body (upside down)? <br />Do both plugs appear identical?<br />What happens when you run the throttle up? Does the engine die or does it just go slow? Are you doing this test in gear on the water?<br />How did the engine perform before installing the carb kit? <br />Are all the throttle linkages set as they should be? Is the armature plate (under the flywheel) moving freely? The throttle plate is opening fully at full throttle?<br /><br />By the way, do not operate that engine above 1500rpms without a load on it. Also, you might find J6C spark plugs better for you engine. They're the recomended ones and are hotter than the J4C's, so they'll tend to foul less. I'm sure that's not the cause of your problem though.
buddie989
hi thanks for the responce <br />the primer bulb dosent get hard and the float was flush and level when i put it in do i need to recheck this <br />when you throttle the motor up it dosent die it just slows down<br />i am doing all this with motor in neturel in a 25 gal tank of water <br />prior to carb being rebuilt it would rev hard til ran out of feul in bowel and die out <br />carb was pluged bad <br />i think i throttle linkages are ok cause i can see the carb linkage open and close all the way <br /><br />i am going to get new fuel line and try that <br />i am thinking it is getting to much fuel woudl carb float be to blame and if so do do i get it perfect <br /><br />thank you
Paul Moir
Sorry to be getting back to you so late.<br /><br />I'd focus in on the main circuit of the carb. One thing to check is the little gasket on the bottom of the main jet. It's still there right? I'm thinking you might be leaking gas past that, causing you to run rich. There should be a lot of smoke caused by this too.<br /><br />When you pump up the primer, your not getting any gas flowing out the carb are you? That would point to a float or needle&seat problem. If there's no gas, try replacing the primer bulb. <br /><br />If you were careful setting the float level, I doubt it's your problem. I was really asking if you had set the float level at all. :) <br /><br />Please put your engine in gear when your testing it. Reving these engines at all can lead to run-away, where the engine spins up to very high rpms all on it's own. This can lead to both engine and heart failure.<br /><br />So find out about that primer bulb, and then go after the carb again.
buddie989
i do have a lot of smoke and the gasket on the main jet was creaked the carb kit did not come with one how do i find one to fit that could be it
