Re: drill hole in prop?
What is your reason to want to drill the prop?Are you wanting to convert it to a vented prop that will get your rig out of the hole quicker?If so,It can be done ,however the holes will need to be at the proper location on the hub ahead of the leading edges of the prop blades.Sizing of the holes is also necessary to achieve the proper results.I could explain the location to place the holes but I don't want to mislead you.See if you can visit a local prop shop or dealer and either have them perform this for you or observe the placement and demensions of one that is already vented.
