Went to lake yesterday and noticed while at WOT that the telltale was spitting water, not a steady stream. Backed off the throttle and water was a steady stream again. The motor is a Johnson 150 GT (YR 1988 V-6). I had recently changed the impeller housing and impeller, along with 2 new thermostats and headgaskets. The boat has been run 6 times since then and have had no problems. The motor doesn't seem to be overheating because after a long run I pulled engine cover off and put hands on both heads and is not hot to the touch. My question is: Is this normal not to have a steady stream of water at WOT or what?
