Hi,<br />have a 25hp of unknown year(serial a2402771) seems like early 80's.<br />Problem is that engine was running fine and cut out upon backing off throttle while slowing down from planing speed - the prop hit bottom about 30 secs before but kept running (engine ran fine until this happened) checked engine and key had sheared on flywheel(probably from the pissing and farting while trying to restart - flywheel bolt was not tightened properly) . replaced key, plugs , cleaned carb and tried to restart. The engine ran for about two minutes and died and would only run with choke out. also needs mixture screwed all the way in to run.<br />seems to be starving for fuel badly but has me stumped where to start.<br />Sound familiar to anybody? Am thinking of checking fuel pump then reeds then crankcase for leaks.<br />Any ideas or tips would be much appreciated.<br />engine has always run faultlessly until this time and am assuming has been running with mixture all the way in since I purchased it about a year ago.
