Hello,<br /><br />I am rebuilding the powerhead of my '78 Johnson 55 HP, with a used crankshaft and new lower, middle and upper bearings.<br />A mechanic measured the crankshaft journals and they are within specifications.<br />After assembly of the powerhead I can feel some play on the crankshaft when I move the flywheel. The play is not up/down, but in the same direction as the pistons travel.<br />I don't know how I can measure the amount of play, so I can't really tell how much play it is.<br />The play is on the upper bearing, not within the flywheel/crankshaft (flywheel is properly mounted). <br />The Cylinder & crankcase are flat to each other and the the right amount of torque is applied.<br />So my only guess is that some play is normal, or the bearing isn't right.<br /><br />Can anybody tell something about this?<br /><br />Sorry for my bad english, I hope you all understand what I wrote.<br /><br />Cor
