I just put new stats in my omc, and on the port engine, I removed the cover, removed the rubber gasket, and put the new gasket and t-stat (screws onto gasket in middle) back in. I notice the small (about 1") rubber seal on the inside of the block. I guess this is where the stat expands into and seals? Now the odd thing. I opened the covers on the starboard engine and there were two metal rings that looked like they would hold the rubber washer just lying in the bottom of the block. What are these? The rubber rings didn't even fit back into the block nor the metal because they were just a bit too small. What is supposed to be under the t-stat cover? I know the rubber seal with the stat. But what goes where the head of the stat sits on the inside of the block? Thanks!
