Re: New to me Evinrude 15
Ok. Whew. I just got back in from working on the new motor and I wanted to post my results and thank everyone again for posting help previously.<br /><br />Here's what I did:<br /><br />I unplugged the spark plugs, drained the gear lube, and then dropped the lower unit about a half inch. I disconnected the shift rod linkage (what a pain the last person put the screw in TOO tight!) the lower unit came off, I took off the pump housing and pulled off the old impeller (making note which way the spines were going). Here's where it got interesting - I bought 2 impellers - I figured it was good to have a spare..well, the first one just wouldn't slide down the shaft so after 15 mins of confusion, I tried the spare one and it fit just fine...WEIRD! I put the key back in and put the lower unit back together. Getting the shift rod linkage back together was difficult.. hard to get the screw back into the hole because it's such a small space.<br /><br />After I got the lower unit back on, I filled it up with new gear lube and then I pulled out one of the spark plugs and hooked up the compression guage. I pulled the starter cord 6 or 7 times and got my reading and then put a new plug in and did the same thing with the other cyl.<br /><br />I put on the muffs, turned the hose on half way or so, and then started up the motor. It started right up and seems to run really well. It idles waaayy down.<br /><br />So, the only thing I have left to do is investigate a problem I might have found with the compression test and I sure would like any help anyone can offer. The guage read 90 PSI on the first cyl. and 85 PSI on the 2nd. From what I understand it should be at least 100 PSI. I tested while the motor was cold. Should I test it when it warm? Also, I guess I'm not 100% sure I had the guage screwed all the way in the block. It uses a different size driver than the spark plug socket so I ended up using some slip joints to get it tight.<br /><br />What does everyone think?<br /><br />Sorry for the long post - I figured if I documented everything, maybe it'll help someone in the future if they search the forum..
