Did a search on VRO pumps, and learned a lot, but still have some questions.<br /><br />What year did OMC change the VRO pumps from 3 to 4 wire?<br /><br />If you currently have a 3 wire, how does the 4 wire plug fit into what ever it plugs into? Is there some sort of conversion kit or does the 4th wire not run through the plug? Hope that made sense!<br /><br />Can the 4 wire pump be rebuilt if it should fail or do you have to buy a whole new pump again?<br /><br />As always, thanks for the input.<br /><br />Cheers,<br /><br />Brew
