  #1
Old May 24th, 2004, 11:01 AM
ponycrony ponycrony is offline
Default HELP! Trouble installing Throttle control cable on 1991 Evinrude 9.9 Yachttwin
I have a 1991 Evinrude 9.9 Yachttwin. Once the throttle control cable enters the front of the outboard, it has to go around other parts to connect to the throttle arm. Therefore, it forces the throttle cable to go in at an angle. As a result, when you use the throttle remote, the cable jumps out of the fitting where it enters the outboard. Is it the aftermarket cable or am I connecting it wrong?Thanks for any input.
  #2
Old May 25th, 2004, 01:36 PM
Default Re: HELP! Trouble installing Throttle control cable on 1991 Evinrude 9.9 Yachtt
bump
  #3
Old May 27th, 2004, 09:35 PM
bump
  #4
Old June 26th, 2004, 05:56 AM
grump grump is offline
Quote:
Originally posted by ponycrony: I have a 1991 Evinrude 9.9 Yachttwin. Once the throttle control cable enters the front of the outboard, it has to go around other parts to connect to the throttle arm. Therefore, it forces the throttle cable to go in at an angle. As a result, when you use the throttle remote, the cable jumps out of the fitting where it enters the outboard. Is it the aftermarket cable or am I connecting it wrong?Thanks for any input.
  #5
Old June 26th, 2004, 06:00 AM
ponycrony, I have the same motor and would also like to install a remote throttle. Did you get something to work for your motor? What did you use for a throttle control?Any info would be apreciated. Thanks
  #6
Old June 26th, 2004, 08:50 AM
OBJ's Avatar
OBJ OBJ is offline
Pony....what kind of connector or holding device are you using to hold the throttle cable in place with? Are the cables you are using for throttle and shift, OMC/Bomby or generics? If it's generic, is there a knurled trunion on the cable where it goes through the front of the engine?
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Shift/Throttle Cable in Control Box Greycup180 Johnson & Evinrude Outboards 7 October 23rd, 2006 12:05 PM
INSTALLING A NEW THROTTLE CONTROL?? payton Boat Topics and Questions (not engine topics) 2 September 14th, 2004 09:25 AM
'76 tri-sonic throttle control box and cable tjmorris Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 April 20th, 2004 11:13 AM
Throttle Control Cable for 1964 Evinrude mike5097 Johnson & Evinrude Outboards 6 February 11th, 2004 10:16 AM
Throttle Control Cable For a Merc NathanY Mercury & Mariner Outboards 4 March 16th, 2003 03:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
