brother chris
- Jul 28, 2002
- 2,063
Okay, I am changing my impellor on my 1978 55hp Evinrude. I am trying to save some of my pocket change by doing this myself.<br /> It all sounds easy enough, but when I took the 6 bolts out, the exhaust houseing only dropped about 6 inches.... I do have a manual, but I am confused about something. <br />In the manual, at the beginning of chapter 8, there is a description of the lower unit and there is a picture of a nut of some sort being disconnected between the exhaust housing and the leg. The picture looks like a 4-15hp o/b, but mine is a 55hp. So I don't know if this relates to my situation? <br />There is no nut as it says to disconnect.(oh, okay, the picture says it is disconnecting the shift connector). But still, there is nothing there to disconnect on my motor. <br />I know this is a simple procedure to do, but I neeed help cause I can't figure it out. <br />Oh, I tried putting it in reverse and the leg seem to drop a bit, and when I put it in forward, it went up a bit. <br />I just read that when installing the lower unit,that the spark plug wires are disconnected from the spark plugs...why would you disconnect the spark plug wires in the first place? <br /><br />I hope all this does not sound stupid, and I bet once I actually finish the job I will feel like an idiot(cause I know this is a simple task). <br /><br />Thanks in advance for any help.
