walleye052974
- Aug 27, 2003
- 18
115 johnson model# on tilt/trim 115ml79r model# on welch plug 115ml78o. so some is 78 some is 79. what I need is to rejet my carbs and the carbs are somewhere between 80-82? The engine has injection instead of choke. the jets which are in the carbs are not listed anywhere for any engine of any year. carb casting # is 325415. bought this whole thing used a couple years ago and it runs just if you can get it to idle it takes a long time to plane if you get it to plane quickly it won't idle. still if it weren't for the trip to sea level i wouldn't worry about it. thanks
