I have an 89 Johnson 200hp looper. After running the boat for 1.5-2hrs at 3500 to 5500 rpm, the warning horn will go off at 1-2 second intervals. I reduce the rpm by a couple of hundred rpm and it goes out. A few minutes later it may or may not go off again. As long as I stay at 3500 or under, it doesnt go off. Was told to check anti-siphon valve, but found the tank fitting had been run without one. Any ideas? Theres some really good input on this site.
