Re: 78 15HP, wont start after wash
Pulled the flywheel. Looked like it got wet under there as there was a bit or rust forming on the electrical parts. Cleaned that all up, still wouldnt start. Went and picked up a set of new plugs and starting fluid. Pumped the starting fluid in the cylinders and it finaly started after a few minutes of messing with it.<br /><br />This was yesterday BTW. Then we let it sit for a few hours and wouldnt start again. Put it away for the night after that.<br /><br />Today, i took the carb off to check it out, it was as clean as clean can be, so i put it back on. It was full of fuel so i know its working right. <br /><br />I pulled the plugs and they were soaked. What im thinking now is, the throttle stop is not letting it get ANY air, or almost NONE at all. The stop that prevents it from being started in gear and the throttle stop that lets the throttle move only so far for when starting the engine, i think are outta wak.<br /><br />I disconnected the stop that prevents it from being started in gear (can get more throttle this way) and the stop that only lets the throttle go so far when in nutruel are readjusted now.<br /><br />Didnt have time today to play with it anymore, or go get new fuel lines (they are both dry rotted) so ill have to wait a few more days to get it outside and try and see what these things will do, since we are expecting 1 to 3 inches of snow tonight and tomorrow.<br /><br />Seems to me, the engine is getting plenty of fuel but not any air. Nevermind the choke, the carbs butterfly wasnt openning hardly at all. If ya follow me....<br /><br />Any thoughts on my progress?
