Re: 30 hp evinrude pull primer
Not to jump the post, but no, when the primer has no power to it, you should not have any fuel going through it, although fuel will be present at the primer and ready to use, if needed. I hope this is what you are asking.... BTW- OB is correct. When you have to keep the primer open for it to run, you have a blockage in the carbs or the float is partially stuck closed. Rebuild it and clean the passages out with carb cleaner and blow them out with compressed air. The primer shoots fuel directly into the cylinders and that's why it continues to run when it is partially open..
__________________
Rick
"Boating is Life...All the rest is just Details"
