Hello everyone!<br /><br />I was hoping someone could help me. I have a 1985 evinrude 4 hp motor. I can only get it to start with the throttle 3/4 full. It will then idle when you move the throttle lever close to idle but eventually stop. When in neutral I can rev the motor to high rpm. when I put it in gear it bogs down. You can give it full power and it goes 1/4 speed. If you pull the lower end out of the water it seems to rev up to full power but put it back in the water it slows down. I just put new spark plugs in. The primer bulb stays pumped. The engine dies immediately when fully choked and will not start choked. I pulled the bottom spark plug wire off while the engine was running and it continues to run, put it back on and pull the top off it dies. I don't know enough to diagnose much further. Hoping someone with more insight could help.<br /><br />Thanks<br />Ashton
