Re: spark plug gap
I run my 91' 70 HP Rude Motor at .040. It idles better and runs better at lower speeds at that setting and no plug fouling. And I do troll alot of the time, also. I have always run my OMC motors at .040, including my 89' 28 HP Johnson. Both Still goin' strong, too. You will probably not notice any top end gain from this. 5900 RPM's is right where you want to be. I wouldn't change the prop if I were you if the motor height is correct.
