Evinrude Fisherman 6HP
marc350
G'day<br />I would like to find out what year my Evinrude Fisherman is, what the spark plug gap should be and how to change the contact breaker points. The model number is: 6402C<br />The serial number is: A104433<br />I have searched the forums but couldn't find this information. Also the spark plugs in the motor are Champion L-7J. Is there a better spark plug to use or are they all relatively similar? I would like to try to squeeze a bit more top end speed out of her!<br />Thank you<br />Marc
rickdb1boat
Re: Evinrude Fisherman 6HP
That's a 1974 6 HP ya got there. Recommended Spark plug is Champion J6C gapped at .030. You will need to pull the flywheel to change or adjust the points. A flywheel puller is nessesary for the job. Point gap is .020.<br /><br /> Points
marc350
Thanks for the info Rick. Once I remove the flywheel is the rest of the job pretty straight forward? I gap the points on my cars - I'm guessing it would be the same process. Forgive me if I sound stupid but I haven't done much work on outboards and its probably not worth buying a manual for it. Thanks for your reply.<br />Marc
JB
G'Day, Marc.<br /><br />Though the Fisherman is a pretty simple engine, if you plan to work on it it is worthwhile to use a Repair Manual. Even a simple mistake can cost you more than a manual.<br /><br />I am not sure what usual practice is in Oz, but here our local Library usually has a manual for loan or for legally copying selected sections.<br /><br />Good luck. :)
marc350
Fair point JB. I think I'll check out the library then have a crack at it.<br />Marc
marc350
Couldn't find a manual at my local library so I had a go at replacing my points, condensers and popped in a couple of new plugs at the same time. Went back together without any probs but seemed a big sluggish when I went for a test. When the points are open, how do I get the gap correct? (when the points open they are not parallel to each other but open in sort of like a wedge shape) Am I supposed to file the points to make the surfaces parallel? (kinda defeats the purpose of renewing them) Or is there a trick to it? Any help is appreciated.<br /><br />Thanks<br />Marc
Chinewalker
Gap the points .020" with the cam rider aligned with the crankshaft keyway... Wdge-shaped is fine when they're open, as long as they're parallel when closed...<br />- Scott
