nitronugget
- Feb 13, 2004
- 3
Hi there,<br /> I have a small problem with my 25 hp Evinrude outboard ( model 2540ZM ). It has developed a rather harsh clunk at high speeds only, the first time it happened I thought I had hit a log or something. I have read through similar topics in the forums that indicate a worn Dog clutch however there a few things that dont make sense. The fault only occurs at high rpm in a plane, when it is under full load pushing into a plane the fault does not occur. I have also noticed that if I hold presure on the gear selector lever , in the forward position , the fault does not occur at all. Is it an indication of a worn dog? Or is there some kind of selector asembly adjustment or repair that may fix the problem. <br />Thanx for your help.
