Gone Coastal
- Feb 11, 2004
- 2
I have a 1986 Johnson 225 That has had the VRO removed. It starves for fuel at 5000 RPM. I brought it to an authorized Johnson dealer who rebuilt all 6 carbs and replaced both fuel pumps. The motor runs great but still only to 5000 RPM. He changed all fiters tightened all connections, same problem. He hooked it directly to his own fuel tank same problem. He confirmed problem was fuel by having assistant squeeze primer ball when motor started cutting out and it ran up to 5500 RPM. He said he is at a loss as to what else to do. Any suggestions?
