njfishman1
- Feb 7, 2004
- 1
I have a 21.5' Seawswirl Striper walkaround with a 150 hp Johnson Oceanrunner(1997). The motor runs strong but when it is at WOT throttle I am a little low on the RPM side. When I bought the boat new it came with a 15"x17" aluminum prop. With a full load I run about 4800-4900 RPMs, so I switched to a 15.5"x15" aluminum and my RPMs went to 5000-5100RPMs. Although I did get the RPMs I was looking for I lost 2-4 knots at my cruising and top end speed. I put the 15"x17" back on. This year I am looking to get the Renegade Offshore Prop. I was looking at the 14-1/2" x 17". Do you think this will help? Is this the right size to go from the aluminum 3 blade? What kind of performance can I expect? <br /><br />Thanks for any help you can provide.
