  #1
Old May 5th, 2004, 06:23 AM
Bruce San Bruce San is offline
Default '88 evinrude 150, adjusting neutral center
I'm ordering a manual from outboard wizard but I'd like to use my boat this weekend. I'm having a shifting problem and was told to adjust neutral center. The manuals I can get here locally don't cover it. can one of you gentlemen tell me the proceedure? Unless it's just too much typing. (I'd understand) THANKS!
  #2
Old May 5th, 2004, 06:55 AM
ob ob is offline
Default Re: '88 evinrude 150, adjusting neutral center
Place the boat controls in neutral.Locate the shift arm under the motor cover.Its the steel rod bent at 90 degrees that connects the shift lever and the shift rod.Remove the pivot pin and while spinning the prop(with your foot if you're good)shift the gearcase in forward using just the shift arm.Now shift back to neutral position .You should be able to feel the detent .Now examine the alignment of the holes of the removed pin and if necessary adjust the shift cable trunion nut until the holes are exactly aligned and pin will insert easily.
  #3
Old May 5th, 2004, 09:32 AM
ob, thanks a lot! I'll try it tonight.
  #4
Old May 5th, 2004, 10:57 AM
clanton clanton is offline
The manual says to shift gear case in farward gear, move control handle to farward gear about 3/4 throttle, adjust trunnion (adjuster) until cable will just slip over shift linkage, after you pull slack from inner cable. Then shift into neutral, to check detent.
  #5
Old May 5th, 2004, 12:01 PM
Thanks clanton. Where is Labelle?
  #6
Old May 6th, 2004, 04:25 AM
ob and clanton, I did it both ways. Same result. the thing is shifting as near to perfect as it can. Thank you VERY much for your help.
  #7
Old May 6th, 2004, 07:27 AM
ob ob is offline
Good for you Bruce and thanks for posting back.
  #8
Old May 6th, 2004, 03:45 PM
Labelle is east of Ft Myers, Florida on the Caloosahatchee river.
  #9
Old May 7th, 2004, 10:12 AM
Cool. I've got a sister in Pine Island. I live near st. Petersburg. Anyhow, thanks again for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude misfiring after adjusting throttle linkage Walker Johnson & Evinrude Outboards 1 July 4th, 2006 11:41 AM
adjusting idle, 1984 evinrude 70 hp blhpzlb Johnson & Evinrude Outboards 2 May 9th, 2005 01:52 PM
adjusting carb to run smother on 78 200hp Evinrude 70wellcraftV20 Johnson & Evinrude Outboards 15 April 25th, 2005 08:46 AM
adjusting the carb on a 77 25 hp evinrude tdr9499 Johnson & Evinrude Outboards 1 December 18th, 2003 05:19 PM
adjusting points on a 9.5 evinrude wayne h Johnson & Evinrude Outboards 2 June 12th, 2003 03:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
