phatmanmike
- Oct 24, 2003
- 3,869
just got my 1980 50hp 2cyl repaired, it was the stator...has rebuilt carbs and new waterpump, all work done by shop were i purchased it...it takes a while to get it to start, like its some old 1963 ford pickup, but once it starts, i have to use the idle rev lever on the controls open all the way just to start it. when i use the idle rev lever, it doesnt really push the throttle back very far, is it supposed to be able to go WOT with that lever, casue it doesnt.and i put it in gear it dies, unless i switch reall quickly into gear, and once in gear, it wont even go high enough in rpms to plane the boat. boat is a 1986 bonito 16.5 foot CC. prop is brand newmichagan wheel aluminum 17 pitch..dont have tach yet, but motor is real quiet and top speed was no faster than the 40 foot sail boat we were running next to.. the fuel bulb does not get all the way hard, and the throttle plates do open all the way.. could this be fuel pump related.. any ideas thanks in advance !
