Ross J
- Nov 30, 2001
- 1,119
Tilt/trim wire found broken clean off. Me thinks problem easily solved so I replaced the wire and it didn't work.<br />I looked around and traced all the appropriate wiring and nothing obvious was found. At the last moment I tweaked the tilt switch and the blasted thing worked just fine. I sat there for 15 minutes, up, down, up, down and it worked just fine.<br />Question - I'm wondering if tweaking the connections whilst I was looking about may have helped. Can anybody think of an obvious reason for this to come right?<br />Ross
