I have a 1992 Johnson OceanRunner 150hp. Motor runs great, but had 2 issues where motor stalled after running for a while at about 3/4 throttle. First time took forever to trouble shoot and found that the optic sensor in the top casing seemed to be the culprit. Installed a new one and fired up first try. Reinstalled one in question to try and verify that it was the problem and symtom came back. <br />Put the new sensor one back in and ran great until last trip out this past season and same symtoms again. This time went through same procedure only replaced optic sensor first shot. Motor fired up first try. And seems to be fine.<br />I Will not get to run the motor again til spring but I am curious if I may have a bigger problem that is causing issues with the sensor. Would rather break it down now during the winter months and have ready for spring than have an issue during the short season we get. Any thoughts would be great.<br />Thanks
