Help '77 johnson 115 died suddenly
JORX81@AOL.COM
115 just died all the sudden. obviously an ignition problem, no spark to any plugs.<br />Any ideas?<br />how do i test ignition?<br />thanks<br />Joe
crazy charlie
Re: Help '77 johnson 115 died suddenly
If I remember correctly,the older jonnies had some powerpack troubles,you may want to start there.And check all elect.connections that you can find.Charlie
JORX81@AOL.COM
Excuse my ignorance, but how can I test thew power pack, and if it needsw replacing who would have a reasonable price?<br /><br />It was like shutting the key off when it quit.<br />it turned over but would not fire at any plug.<br />the engine dosen't have a lot of hours on it, it's been out 2 or 3 times max each summer since bought new in 78 a many years it was never used at all.<br /><br />Thanks<br />Joe
Joe Reeves
Jorx..... Remove the "Black/Yellow wire form the powerpack, then check the ignition (spark). If all is well, replace the ignition switch.<br /><br />If still no spark, in all probability, the powerpack has failed, in which case, replace it.<br /><br />Note: Even if a new powerpack does not cure the problem, assuming that the test in the first paragraph resulted in still no spark, it's a good idea to have a spare pack for emergencies.<br /><br />Let us know what you find.
