Idle RPM on 70hp johnson
Javelin 353
I just got my boat out of the shop had all the carbs rebuilt and engine tuned. Idle rpm is about 1100 rpm on the ears. I thought this was a little high. Mechanic said he likes to set older johnnys at that rpm mine is a 1991???
rickdb1boat
Re: Idle RPM on 70hp johnson
You are a little high on with the idle. Better way to check it is in the water in gear. Should be 725+-25 RPM's in gear unrestrained and moving. I too, have a 91 70 HP rude. I believe mine idles in gear about 750-800 RPM's. Easier on the clutch dogs and gears when shifting if the idle is lower.
