Re: 1988 88hp Evinrude P T/T
irdir,<br />I am planning the same upgrade. I have the tilt unit but never put it on yet. Tried once but I am quite sure you need to pull the motor off the boat to get the pump in place. The manual cyclinder/damper comes out pretty easy on the boat, but there was no way I could get the power unit in place.<br /><br />I'd be very interested in how you make out.<br /><br />The only item that I still need are a couple steel pads that bolt intothe bracket where the trim rods hit. Do you have these to install on your motor?
