I am working on a freinds boat,he got stuck in the mud and "overheated it a little" now there is water coming out from around the head gasket and there is water on the plugs.It has been flushed and the water pump works.<br />The thermostat or temp sensor(rubber grommet with a wire coming out in the head)wire has the sheath melted off but it started right up ,ran and more or less idled.<br />Should I just start with the head gasket and see where it takes me or is it probly more serious than that.<br />1974 Evinrude 50 Horse 2 cylinder-Big gear case -Model #50473N-Serial #E002102<br />As I said it started right up(been sitting for 3 years) and ran fine,compression is not spectacular but o.k.<br />Thanks for any help<br />5150
