I hope you guys can help with this problem, there is a ton of experience on this site and it seems as though all you fellas are very helpful. I've looked at a ton of posts on various similar problems, but have yet to get a definite answer. The motor I have starts and idles fine, when I gun the accelerator the engine never gets above 1/4 power. Basically WOT and it feels like I barely have it idling in gear. As soon as I hit the primer switch on the ignition, she takes off running. Then about five seconds later I come back to reality. <br />I have bypassed the VRO and capped the oil line, about two months ago it ran fine, then it bogged down and started surging, now it is stuck bogging. I have replaced the fuel tank, fuel line(including bulb), fuel filter between fuel pump and carb, and the fuel pump. <br />Could there be an ignition problem? My mind tells me that it is a fuel problem because when the primer switch is hit, it takes off like a bat out of hell.<br /><br />Thanks<br />Stan
