Re: 85-140hp out of the same block? How?
There isn't as much difference as you might expect between the 85 and 140. The 85 is tuned for low & mid-range power, and will "feel" stronger than a 140 in that range. For example, it'll pop a skier up easier. The 140 needs to get wound up before it can pull hard. <br /><br />Further, the 140 burns out easier. Properly-tuned & propped, 140s can be run full-throttle 24x7. But clog up a carb jet so a cylinder runs lean, and it's more prone to overheating than an 85 would be. <br /><br />OMC also made 150 to 235hp from a 150 cubic inch V6, and 55 to 75hp triples from a 50 cubic inch triple. Swapping a 85hp V4 onto a boat that had the 75hp triple, the first thing you'll notice is that the 85hp feels a ton stronger - accelerates like you've downshifted a gear in your car. The second thing you'll notice is your gas gauge now drops like a stone...
